Message 1 of 3
All4 App issues? Power line issue?
Hi,
My YouView+ worked fine when wired directly to the router. I have since bought a broadband extender flex 600.
I originally had an extension plugged into this which caused occasional distorted picture on channels like comedy central, bt sport, etc so I removed the extension from the extender.
It seemed okay but now I am having an issue while watching the All4 app, usually after watching a program for a while it shows the loading screen and the shows an error message saying there is either an issue with my internet connection/bandwidth or their servers (I assume not their servers as happens a lot)
I have since started using the same app on my Xbox 360 over wifi with no issue so I assume it is the power line adapter.
Any help/tips? Maybe some configuration settings I can tweak.
Real shame the YouView doesn't come with wi-fi connection, I have no problems whatsoever streaming full HD over wifi on all my other devices.
2 REPLIES 2
Message 2 of 3
Re: All4 App issues? Power line issue?
The new BT Humax box seems to be very picky about how it is routed to the hub. I have my hub upstairs but only have a single CAT 5 cable running downstairs. I was using a TP Link access point as a WAP/switch downstairs but the BTTV box refused to connect to BT Sports. I replaced the TP Link with a redundant HH5 also just acting as a WAP/switch and all is fine. I can only assume that the QoS or multiplexing or something is different in the TP Link.
Message 3 of 3
The TP Link is not passing the multicast packets that are needed for Internet delivered content.
