RichTeaBiscuit
Message 1 of 2
Alternative to HH5 - FTTP
Hello,
Any recommendations for an alternative to a HH5? I have FTTP - 300/30.
Can I use this? Linksys WRT1900AC Smart Wi-Fi Route
Below is a picture of the Openreach box. This is connected to my HH5.
1 REPLY 1
ray_dorset
Distinguished Guru
Message 2 of 2
Re: Alternative to HH5 - FTTP
Yes, you can use any router than can setup a PPPOE connection. They used to be called cable routers.
That Linksys looks ideal
Or the Apple AirPort Extreme
Or the Asus RT-AC68 etc.
If not, I'll try again 🙂
