Message 1 of 2
Alternative
Can anyone tell me whether my current router is a viable alternative to the one supplied at installation with Infinity. I am unsure if this is suitable. Linksys wag 320 n Dual band wireless adsl 2+ Modem gigabit router. It has worked flawlessly and I have read so many problems with the Bt offering.
1 REPLY 1
Guru
Message 2 of 2
Re: Alternative
Hi, unfortunately no it isn't as it is only an ADSL2+ router, you will need a VDSL cable router to suffice. Make sure if you do invest in another router it supports PPPoE.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
