Message 1 of 7
Alternatives to Bt Infinity Data Extention kit?
Hey guys, my family and I have recently moved alot of the devices in our house around, such as Xbox 360 and as such have to connect wirelessly. We are currently using "powerline" which is like a 1/2 wireless 1/2 wired connection, but it doesn't quite cut it to a complete wired connection.
I rang up BT yesterday and asked them how much it would be to install the Data extention kit, only to find out it's £205! which is absolutely ridiculous.
What other alternatives do I have now to make my connection fully wired? Please help 🙂
6 REPLIES 6
Message 2 of 7
Re: Alternatives to Bt Infinity Data Extention kit?
This should be long enogh for most needs Smiley Wink
Run it between the Active NTE fitted by BTOR and wherever you want your HomeHub then connect your other devices using shorther patch leads
DISCLAIMER: although I work in the industry I do not work for BT and any opinions given are purely my own.
Message 3 of 7
 You could have the master socket moved if that suits you better. I had mine moved upstairs at no cost when the engineer did the install, as the stuff I want hardwired is up there.
Message 4 of 7
Thankyou for the replies guys 🙂
I would buy a long ethernet cable however, it would be really messy and impractical so I don't think I can go that route.
Do you know how much it costs to move the master socket :3 ? Also, I don't have a telephone socket in my room, which is where I want to move the hub, does moving the master socket involve changing an existing socket, becuase I wouldn't have that option 😕
Message 5 of 7
I'm sure there's an official charge.
The unofficial charge (depending on how receptive the engineer is) is generally taken as tea,biscuits and if you're feeling generous bacon butties 🙂
Message 6 of 7
Do you already have infinity installed?
Message 7 of 7
Yes I do.
