Message 1 of 10
Am I being throttled by BT?
Hi All,
I have a general speed issue, when I complain about it to BT it gets fixed, for about a month then returns.  I had one tengineer come out and said he had swapped the ports at the exchange for me (Or something like that) and this lasted about 3 months, then like a switch went back to normal (im thinking someone swapped me back).
Any way the real issue is that in addition to the general slow speeds, I am also finding that at 4pm any and everyday my speed drops by to 1mb or under, I have even downloaded a big file from 3:45 and noticed as soon as it hits 4pm it drops, I can understand it dropping off "slightly" due to increased traffic but I can imagine everyone decides to use their internet at 4pm every day......
Can someone help me understand what is going on?  I have a fault open with BT on my line currently about this, but its been 3 days now and each day I have been told it will be fixed, Lies! but I am pleased that I am getting the call backs.
9 REPLIES 9
Message 2 of 10
Re: Am I being throttled by BT?
Also just found out that I can receive up to 5mb speed but for some reason my IP profile is 3mb? Or am i being a dim wit!
Message 3 of 10
Hi Welcome to the forums
If you post the full stats from your router
For homehub – type 192.168.1.254 into your browser
Navigate to ADSL Settings or use the A-Z at the top right of the home page and scroll down to ADSL Settings and click on it
Click on More Details and then post the full results.
also post the full results from http://speedtester.bt.com/
or http://bt.custhelp.com/app/answers/detail/a_id/9354/c/346,4740,5520 and post the results .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
Then someone here may be able to help and offer more advice.
This is a customer to customer self help forum the only BT presence here are the forum moderators
Message 4 of 10
VPI/VCI 0/38
Type PPPoA
Modulation G.992.1 Annex A
Latency type Interleaved
Noise margin (Down/Up) 16.3 dB / 23.0 dB
Line attenuation (Down/Up) 43.4 dB / 27.0 dB
Output power (Down/Up) 5.7 dBm / 1.6 dBm
Loss of Framing (Local/Remote) 0 / 0
Loss of Signal (Local/Remote) 0 / 0
Loss of Power (Local/Remote) 0 / 0
FEC Errors (Down/Up) 3444 / 218
CRC Errors (Down/Up) 3094 / 74
HEC Errors (Down/Up) 8779 / 32
Error Seconds (Local/Remote) 1959 / 85
I have to wait for the speed test as it wont load up for me, connection lost.
Message 5 of 10
hi sorry to be a pain but could you repost your hub stats again including the connection time and connection speed
Message 6 of 10
Line state Connected
Connection time 6 days, 22:24:26
Downstream 3,488 Kbps
Upstream 448 Kbps
ADSL Settings
VPI/VCI 0/38
Type PPPoA
Noise margin (Down/Up) 16.6 dB / 23.0 dB
FEC Errors (Down/Up) 3493 / 218
CRC Errors (Down/Up) 3122 / 74
HEC Errors (Down/Up) 8847 / 32
Error Seconds (Local/Remote) 1985 / 85
I appreciate your help, thanks also I just managed to get a speed test done, see below the stats:
 Download speedachieved during the test was - 753 Kbps
 For your connection, the acceptable range of speeds is 600-7150 Kbps.
 Additional Information:
 Your DSL Connection Rate :3488 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 3000 Kbps
Expert
Message 7 of 10
Your high noise margin is causing the slow speed. After 14 days of solid connection this should decrease but you can contact the mods to get this done quicker. Contact them through this link: http://bt.custhelp.com/app/contact_email/c/4951
If my answer was helpful, please give me a star by clicking the star on the left hand side.
Thank you.
Message 8 of 10
Thanks for the advice I will follow up and let you know if I get a solution.
Expert
Message 9 of 10
The DLM as well as a reasonably stable connection needs a reasonably low error count to reduce the target margin, no idea what the limit is but I know that in my case 20 days into the same connection and it still did nothing, mods are the best solution to get it set to a reasonable value.
If my post was helpful then please click on the Ratings star on the left-hand side If the the reply answers your question fully then please select ’Mark as Accepted Solution’
Message 10 of 10
Hi looking at your stats i would say contact the mods and get them to reset you noise margin this is a link to them
they normally reply by email or phone within 72 hours
They are a UK based specialist team who have a good record at getting problems solved
