oliverghost
Message 1 of 9
Amazon Fire TV stick issues
Hi all, Can anyone help me with this huge headache ! I have been trying all day to get my Amazon Fire Stick connected to my HH 5, Every time i type in my wireless password/key on the fire stick it keeps saying "cannot connect please reboot router or try another connection" I have rebooted router about 15 times today and still the same caption ! i have even tried resetting the Amazon fire stick but still won't connect...The password i type is correct every single time, I was with sky before and never had an issue connecting my fire stick
8 REPLIES 8
Keith_Beddoe
Message 2 of 9
Re: Amazon Fire TV stick issues
Make sure you turn off "smart setup" on the Homehub. See link how to do that.
http://bt.custhelp.com/app/answers/detail/a_id/443​28/~/switching-smart-setup-on-and-off-on-the-bt-h...
See
https://community.bt.com/t5/Connected-Devices-Other/Can-t-stream-anything-on-my-Amazon-fire-stick/m-...
If you have BT Parental controls installed, that may also cause problems.
carolandbernie
Message 3 of 9
Hi Had same problem .I restarted my HH5 it took 2 atempts then ok.
gg30340
Message 4 of 9
Hi carolandbernie
This post is nearly a year old so you may not get a reply from the OP but your post may be helpful to others.
carolandbernie
Message 5 of 9
Hello can anyone advise?
I have installed Amazon fire TV box and can see all app and videos except for ITV player. ITV as well. I have BT Vision box and can get ITV player on this ok on one tv.
When on my Amazon Fire TV box on another TV I can  NOT get past the welcome to BT your home hub is up and running, please sign on in the next page... but it wont do anything. 😞  Amazon Fire TV box has no help subject on this nor does BT (Vision box)
Advise please?
I have an extra old hub4
would this resolve the issue?
thanks folks
licquorice
Message 6 of 9
Turn off smart set up on the hub.
gg30340
Message 7 of 9
carolandbernie
Message 8 of 9
Did not realisze that the home hub set up was the problem. Many thanks for the Link. Works now.
carolandbernie
Message 9 of 9
thanks for your help
