Please can anyone help, we had been using our amazon firestick all the while we had mobile data in our house, once we had wifi put in and I installed BT premium whole home wifi the amazon firestick wont work, comes up as connected with issues and the following error message
too_many_redirects
Please can someone help - i really have had enough of rebooting and retyping passwords etc all to no avail
Solved! Go to Solution.
Try turning off Smart Set up and parental Controls... That should help
Hi Nigel, thanks for this and yes, i had seen this somewhere else but i couldnt find where to turn off smart set up on the new premium whole home wifi pack? can you show me a picture of where this setting is please?
Cheers
http://192.168.1.254 should take you to the hub settings and you can turn it off through their. If it asks for the admin password, that's on the little tab that comes with your hub..
Fantastic, thank you, worked a treat, hope it stays that way.
thanks again
