Message 1 of 7
Amazon Firestick will not connect to WiFi. Please help.
All instructions followed correctly. WiFi located but when WiFi password is entered the following message is received. “Could not contact Amazon.co.uk. Check the router or try another Wireless network.”
I have cancelled WiFi Smart SetUp, divided wireless connections, turned power off and on, restarted router, restarted television, returned Firestick to factory settings ....... followed endless google based advice.
All online advice so far has led to same result.
6 REPLIES 6
Message 2 of 7
Re: Amazon Firestick will not connect to WiFi. Please help.
which bt hub do you have?
Message 3 of 7
Thank you for your message. I have BT Smart Hub - Type A, connected to Fibre with BT Halo 1
Message 4 of 7
have you turned of smart setup
Turn Off smart setup
Message 5 of 7
Yes. Smart setup turned off.
Message 6 of 7
Try making a hotspot on your phone and connect to that to isolate where the problem lies.
Message 7 of 7
Have now tried to connect to Hotspot. Same message, unfortunately.
