Shirleyg52
Message 1 of 5
Amazon fire stick
Hi I have had an amazon fire stick and it wont play so googled it and I need to turn smart setup off so I have followed these instructions:
Open a web browser on any computer or device connected to your Hub and go to http://bthomehub.home to open the Hub Manager.
Select Advanced Settings:
Enter the admin password. ...
Select Continue to Advanced Settings.
Select Home Network > Smart Setup.
Select No to disable Smart Setup & select Apply.
But as I press on home network my internet goes off everytime, any help to stop.this or turn off smary set up would help
Thanks in advance
4 REPLIES 4
john46
Message 2 of 5
Re: Amazon fire stick
which hub are you using
Shirleyg52
Message 3 of 5
Bt home hub 5
john46
Message 4 of 5
have you tried a factory reset of the hub first using the reset pin hole at the rear of the hub hold it in for 20 seconds
Shirleyg52
Message 5 of 5
Sorry been away do.just got around to.trying it
Unfortunately it is still doing the same thing as I click on home network tab it seems to.cut the internet connection
