Message 1 of 10
Android Galaxy Ace won't connect to Home HUB
Not sure if anyone can help here but the"O2 Ghuru" just looked blank at me!
I have just purchased my first smart phone with O2, a Galaxy Ace. When I try to connect to my home hub  (the latest hub from BT) it seems to "disable". This is what I see:
I select WIFI settings
WIFI
Turn on WIFI
My hub shows as "Remembered, secured with WPA/WPA2/PSK"
I get a pop up where I select "connect"
I then get a pop up where I enter the Hub password and select "save"
It then says "Authenticicating but then says ""Disconnect"
The Hub then shows as "Disabled, secured with WPA/WPA2 PSK"
I haven't done anyting with BT FON on my phone but I thought that was when I want to use the hotspots?
Sorry if I'm being thick, please help!
9 REPLIES 9
Distinguished Guru
Distinguished Guru
Message 2 of 10
Re: Android Galaxy Ace won't connect to Home HUB
Sorry if this is stating the obvious, but it sounds as though the hub is not recognising the password you are entering. The phone should connect just as readily as your computer using the key shown on the hub itself, not the password you would use if connecting with BT Fon.
If you're definitely not confusing the two, it might be as well to get an alternative O2 guru to check the phone.
Message 3 of 10
Further to pottypersons advice, once you go into settings>wireless and network>wi fi settings>>wi fi you should see
Wi Fi Networks
Underneath that you should see your BT home hub [eg, 15SQ]
Underneath the above you should see BTOpenzone-H [provided you have opted into Fon]
It may be your device is configured to a different primary wi fi connection, especially if I may suggest the 02 guru was involved in the set up: it could be configured for an 02 source, and not a BT source.
Your home hub should have been configured during the device set up and asked you for your hub wireless key.  If that hasnt happened, that will be the cause of your issue.
I would suggest that you run the set up again, and as pottyperson says put your wireless key for the hub into the box during setup.
Id join Fon and download the BT Fon app from the market place.
Come back if theres still a problem. Smiley Happy
AQ.
"Welcome to Royston Vasey - You'll never leave."
Message 4 of 10
Thanks so much to you both. What a fool I am. I had been typing the admin password rather than the key code. All connected now thanks to your guidance.
Message 5 of 10
Hi crunch,
There are no fools on here - only those who are willing to learn - and those who want to help.
Glad its sorted. Smiley Wink
AQ.
Newbie
Message 6 of 10
Ok I have the same problem and have been putting in the password on the back of the home hub - help! Have downloaded the BT Fon app, should I just connect using that?
Distinguished Guru
Distinguished Guru
Message 7 of 10
The app won't connect to your hub SSID, and Fon is likely to be much slower. You should be able to connect fully with the security key - having previously used the password in error shouldn't affect that.
Message 8 of 10
I have the same problem with a Logicom Tablet running Android 4.1.1
Initially it connected once, then never again until I unplugged the Home Hub and reset it. Wouldnt connect to BTwifi or BTWiFi-with-FON.
Initially it said connecting then saved 9and disabled  the BTWiFi and BTwfi with FON. Left it for 10 miutes and it connected!! I know the SSID and password was the right one.
Rreally frustrating, as it also happened at a relatives house who also has BT Broadband. REsetting their hub did not fix the probem.
Any information on the cause of the problem and how to fix it without rebooting the hub would be good.
Message 9 of 10
Have you tried "forgetting" the connection that you made on the tablet, then switch the tablet off and then on again then remake the connection. Once you have found your homehub SSid click on it. The password is the wireless passkey found on your homehub label not your email password.
See link for connecting Android tablet
http://bt.custhelp.com/app/answers/detail/a_id/44480/~/how-do-i-connect-an-android-tablet-computer-t...
If you are connecting to BTWif then you do need to use your primary email address and password.
See link for connecting to BTWifi
http://www.btwifi.com/help/login-with-bt/connect-using-your-mobile-device.jsp
Message 10 of 10
Check, check and check again that the password is the Wireless passkey from your hub as gg says above Smiley Wink
AQ.
