Storm_Force
Message 1 of 4
Android Market.. can't connect
I have been trying to connect to the android market via my Hero however it keeps saying " Can't establish a reliable data connection to the server" I have tried both wi-fi and mobile interent but no luck. My emails and browser are working fine.
Any idea's?
3 REPLIES 3
Palli
Message 2 of 4
Re: Android Market.. can't connect
I had a similar problem. After googling the problem it seems that a factory reset was the most reliable fix.
Tried settings/applications/manage apps/google apps - clear data but the problem persisted.
Factory reset solved the problem straight away, just need to resync contacts calendar etc.
Hope this helps
LincolnismyDog
Message 3 of 4
Yeh I googled this problem too and seems the only solution is to do a factory reset, which I did last night, just make sure all conatcts are backed up to SIM
is well worth it as some of the Apps are def worth it, u will need to resync contacts and some settings but didint take me long :smileyindifferent:
Storm_Force
Message 4 of 4
Yep factory reset was the only fix, its working fine now 😄
