Andy_c1
Message 1 of 4
Android TV Box cannot connect HH 6
Recently upgraded to HH 6, everything is fine except the android tv box. Tried everything I can find on the net, like turned off smart setup........still no joy. The bix shows it's connected to the hub, just no internet go through. Can anyone help please.
Now I just reuse my HH 5 as main, and the 6 as an access point.
3 REPLIES 3
peter-d-w
Message 2 of 4
Re: Android TV Box cannot connect HH 6
Is your TV box connected wirelessly to the hub? If so you can try changing Wireless Mode to Mode 2 or Mode 3. This may or may not fix it. I hope you get it working!
Andy_c1
Message 3 of 4
Thank you for replying. No, my box is connected by wire.
nix99
Message 4 of 4
I had a similar issue with one of my android tablets - turns out the HH6 was handing out the same IP address to two devices. Check out the HH6 device webpage and have a good look. 🙂
