vix71
Newbie
Message 1 of 27
Android mobile preference to BT FON instead of Home HUb
I recently joined BT FON and entered the world of smart phone users.
I have a android smart phone and have the BT FON app installed.
When I am in range of my own Home Hub my phone tends to connect to BT FON first - which is limited to 512kbps.
How do I stop this happening and not having to manually go in to select Home Hub each time?
I know one section of the Q&A section says to go in and 'forget' the BT FON connection but would that not mean that it would never auto connect at BT FON hot spots when I am out and about????? I obviously want to be able to utilise BT FON wifi spots away from home.
26 REPLIES 26
Message 2 of 27
Re: Android mobile preference to BT FON instead of Home HUb
There is a setting in the apps menu under connection settings. Tick the box which says Prioritise your w-fi networks.
vix71
Newbie
Message 3 of 27
Thanks very much for help will try that!
PeterMidgley
Message 4 of 27
This problem has bugged me for years. I can't find this setting on my Samsung Galaxy Note 4 but I've just installed a free app called Wiman from Google Play Store and this allows me to set preferences and it seems to work
Ozzig
Message 5 of 27
There is an option in the BT WiFi app ...
"Automatically connect me to my home hub when in range"
Though since getting my HH6 the phone does have a tendency to sometimes connect to FON and stick to it until I manually change it.
davidwf
Message 6 of 27
Yes, so does mine and it is very irritating to have to keep changing it back!
Never happened before I got the HH6.....
Anyone found a definitive cure?
Distinguished Expert
Message 7 of 27
Not a definitive answer, it's an Android problem.
If your phone is in standby, keep location services on.
This will speed up the connection to the hub wifi.
At first it connects to btfon, however.
If starting up from off, then make sure that you enable location services, as well as wifi, of course.
Eventually it will connect to the hub.
Jackiow
Message 8 of 27
I've just downloaded the latest version of BT WiFi App and there is no option to Auto connect to HH when in range ?
Message 9 of 27
On the Android app, open it up then go to the three dots at the top right, click on it an scroll down to settings . Scroll down to "Automatically connect to my homehub when in range", tick the box.
Jackiow
Message 10 of 27
There is no option.
5 Options:
Play a sound etc.
Vibrate when connected etc.
Update log in
Auto log in
About the app, licence stuff
