Jackiow
Message 11 of 27
Re: Android mobile preference to BT FON instead of Home HUb
It's only just started happening at Home, before it was in the Garden so I thought it was arange issue, but now it's all the time. |fed up with having to keep changing it. Then it just defaults to wifon again willy nilly.
Message 12 of 27
On the latest app that is on my phone, where you have it shown as "Auto log in" my app shows Automatically connect etc .....
Jackiow
Message 13 of 27
I uninstalled and re downloaded the App again an hour ago so I assume mine is the latest offering.
Message 14 of 27
If you go to the wireless settings and "forget" the BTWifi Fon connection it might stop that from happening.
Message 15 of 27
The app version I have is 7.0.06 config version 3.5
Jackiow
Message 16 of 27
Mine is 7.0.06 version 6.0
Message 17 of 27
I have had the BTWifi app installed for years so I guess the Config Version does not get changed when there is an update which would explain the difference between the two menus.
Distinguished Guru
Distinguished Guru
Message 18 of 27
Google have made some changes which affect logging on to BT WiFi and BT put up a message explaining this when I last opened the app (config version 3.5). I can't remember the details but it meant that you now have to disable auto login if you don't want a permanent notification showing. The changes also seem to have led to the removal of the option to give preference to your home wifi.
I think you'll have to disable auto login and forget all saved BT Wifi networks.
Message 19 of 27
I checked my other Android device and it is the same as your one but it has the same options as on my other device.
Jackiow
Message 20 of 27
I have disabled Auto log on as the Flag stays on the screen otherwise. I've also "forgot" wifon etc  and its seems to have worked so far. I just realised that I changed my phone a few months back and when the BT app was reinstated it was the latest version. Thanks for the help Guru.
