Message 31 of 34
Re: Annoying Internet issues for over Five days.
Scratch that, I shouldn't really trust speedtests from N.Ireland, as no server really is close to me, my router is saying:
Downstream sync speed:
46.33 Mbps
 Upstream sync speed:
16.32 Mbps
If it stays like this for 9 days I'd be happy with that, that upload speed is so much better than before 😛 Does anyone know a good way to test your ping?
Message 32 of 34
Unless you do a lot of multiplayer gaming your ping is more than fine. And if you do game online then just jump into a server and compare what ping your getting now to what you used to.
Message 33 of 34
Good idea about the gaming 🙂 Overwatch has a ping of 32, it was 25 before having issues. I guess things will get better in a couple of days 🙂
Message 34 of 34
Well I think it's safe to say that the issue has been resolved, I'm not sure what type of wizard magic this BT Engineer did but he was very nice and knew what he was doing 🙂
He replaced my filters and said that the under performing broadband that was having had 99.9% to do with how a last Engineer had put in our socket, the whole socket was bad, not sure what he did but anyway, the Engineer also did some configuration changes to the line ( Whatever that means ) and told me the last 1% of the issues I was having was that the DLM was " bugged " on my line, so he also did a full line reset.
The end result is speeds that I have never-ever had on my line before, and the speeds keep on improving.
60.46 Mbps
16.33 Mbps
Awesome BT Engineer 🙂 Thank you.
