imjolly
Message 21 of 25
Re: Another person trying to move from ADSL to ADSL2+...
just because you had max connection spee on adslmax does not mean you would get max speed on adsl2/2+ as you have found out.  it is based on distance from the exchange - check you attenuuation here
check speed
your dslchecker resuly showed an estimated speed of about 10mb
john46
Message 22 of 25
with your attenuation your line length is around 2.5Km from the exchange I would expect a connection speed of around 10 mb this link explains more http://www.kitz.co.uk/adsl/max_speed_calc.php
MonkeyJug
Message 23 of 25
Cheers guys - makes sense now.  I understand the distance to the exchange is not necessarily 'as the crow flies' but I would have hoped that my line was more efficiently routed than 2.5kms!  Apparently not!
Anyway, thanks for all the help and advice.  I'm happy with 10meg... 🐵
john46
Message 24 of 25
Glad to help any time
DavidM
Moderator
Moderator
Message 25 of 25
Hi MonkeyJug,
I'm glad I was able to get this sorted for you. if you have ny further problems post back and we'll be happy to help.
Cheers
David
