Message 1 of 5
Anti-virus software needs renewing?
Hi there, wonder if you can help, please?
I used to use AV software but I removed it after it expired and then I went with the BT McAfee stuff as it was free and I heard it was pretty good.
Installed it no dramas.
Over the last couple of days I noticed the dreaded yellow exclamation mark over the security shield and checked it out, to be told that my subscription to McAfee Virusscan expires soon.
Seeing as I don't have McAfee Virusscan and the BT AV is McAfee, I'm assuming it's that? How do I stop it expiring, as I thought it wouldn't expire?
Cheers!
4 REPLIES 4
Anonymous
Not applicable
Message 2 of 5
Re: Anti-virus software needs renewing?
I don't use Windows myself, (assuming that you are?), but ISTR that if you right click on the McAfee icon in the Task Bar, there is an option to "Verify Subscription"
Message 3 of 5
Great tip, thanks - you're correct that I'm on PC.
I did that and Windows acknowledged it had verified my sub but sadly the yellow exclamation mark hasn't gone.
Maybe it will go in time..?
Message 4 of 5
Don't do anything.
If McAfee have verified your subscription then all is well and it will continue to work, the problem is with Windows Defender
Message 5 of 5
Thanks guys, much appreciated.
