Message 1 of 7
Any one had BT FTTP installed recently - picture of ONT
Hi
Fibre to the Property from BT has just been made available where I live, meaning I can get 900mpbs.
However i know that they must install some new equipment (ONT) for this, does anyone have a picture of a recent install as I am led to believe that the new ONT is smaller and the older one, just need to work out how much wall space I am going to need?
Thanks in advance
6 REPLIES 6
Message 2 of 7
Re: Any one had BT FTTP installed recently - picture of ONT
A quick Google shows......
You can judge the size by the plug.
Message 3 of 7
Thanks, thats the one i seen on google but not sure if they are actually installing these ones in customers properties yet?
Message 4 of 7
As far as I'm aware they are, but not sure if they are also still fitting the older ones.
Hopefully @Starwire  will be along to clarify.
Message 5 of 7
Yes, that’s the ONT Openreach are using now.
Theres supposed to be a new one soon that has no TELE1 Port, unsure if it’ll be any smaller like the Nokia one?
Message 6 of 7
Thanks for the reply @Starwire, so the only box they install now is this one with the fibre cable through the wall? Then obviously Ethernet to smart hub.
Message 7 of 7
Yes.
