Message 1 of 13
Any problems on BT Infinity for Northern Ireland?
Having problems with the speed - just noticed my YouTube videos lagging.
My normal speed is:
http://www.speedtest.net/result/1621538058.png
Now, my speed is...
http://www.speedtest.net/result/1758570772.png
I'm in the Coleraine area. I'm curious to see if anyone else has the problem... Tried resetting my router and modem and nothing has changed.
Cheers,
Darryl.
12 REPLIES 12
Newbie
Message 2 of 13
Re: Any problems on BT Infinity for Northern Ireland?
Yeah, im having the same problems Darryl, only seems to be during peak times also, its working fine normally, then all of a sudden it drops alot.
Im in the Coleraine area also, only seems to have happened since last night.
A friend whos in Portrush doesnt seem to be having any problems with his whatsoever, possibly BT are working on the lines in the Coleraine area?
Cheers,
Mark
Message 3 of 13
Same here in Newtownabbey. Down from 20 to 0.7 Mbs this evening. Hope they get it sorted soon!
Message 4 of 13
same in belfast too, theres a few threads on the fron page here about it, if you could post in those to get the mods attention that would be great
http://community.bt.com/t5/BT-Infinity/problem-with-infinity/td-p/394437
http://community.bt.com/t5/BT-Infinity/Ping-Increase-Infinity/td-p/401253
maybe stick a trace route in there too and your speed test details, and contact the mods as discussed in the threads
to do a trace rout just go
start>run>cmd> then type trace rt www.bbc.co.uk
Message 5 of 13
Same here in Coleraine.. think BT need to look at this.
Message 6 of 13
Im in Portrush and all okay here.
Did a Speedtest just now.
Also thrown in a traceroute to maybe help.
traceroute to bbc.co.uk (212.58.241.131), 64 hops max, 52 byte packets
 1  api (192.168.1.254)  1.921 ms  0.848 ms  0.757 ms
 2  217.32.142.103 (217.32.142.103)  12.875 ms  13.262 ms  12.599 ms
 3  217.32.142.126 (217.32.142.126)  13.716 ms  13.444 ms  13.163 ms
 4  213.120.163.30 (213.120.163.30)  27.112 ms  20.469 ms  20.191 ms
 5  217.32.27.54 (217.32.27.54)  20.419 ms  20.144 ms  21.129 ms
 6  217.32.27.182 (217.32.27.182)  22.213 ms  21.744 ms  21.901 ms
 7  core2-gig7-0-0.manchester.ukcore.bt.net (109.159.250.218)  21.949 ms
    core2-gig10-0-0.manchester.ukcore.bt.net (109.159.250.222)  21.650 ms
    acc2-10gige-0-2-0.mr.21cn-ipp.bt.net (109.159.250.194)  20.409 ms
 8  core1-te0-13-0-0.ilford.ukcore.bt.net (109.159.250.137)  35.287 ms
    core1-te0-4-0-0.ilford.ukcore.bt.net (109.159.250.129)  31.290 ms
    core1-te0-12-0-4.ilford.ukcore.bt.net (109.159.250.133)  30.655 ms
 9  peer2-xe11-0-0.telehouse.ukcore.bt.net (109.159.254.130)  31.216 ms
    peer2-xe9-1-0.telehouse.ukcore.bt.net (109.159.254.114)  60.921 ms  32.443 ms
10  194.74.65.42 (194.74.65.42)  29.929 ms  29.032 ms  29.677 ms
Message 7 of 13
hi everyone i am having problems with bt infinity so much i am getting a visit from an engineer my speed keeps going up and down from as low as 8mbs  i live here in belfast is anyone in the belfast area having any problems thanks for any feedback
Message 8 of 13
I had problems about a month ago, i contacted the forum mods and got it fixed, post a trace to bbc.co.uk and maybe others can help
Message 9 of 13
In Belfast also. Getting evening speeds of between 2-6Mbs. This with an IP profile of 77.43 Mbps which I can usually come close to during off peak periods. Did you ever get any update from BT on this?
Message 10 of 13
as posted by the previous poster he contacted the forum mods and it was resolved for him
