Message 1 of 2
Anyone got a Fritzbox 7390 working with Inifinity 2 Fibre to property ?
Hi
I have 300Mb Infinity 2 Fibre to Property and want to change my Home Hub 4 for a Fritzbox 7390 but try as I may, I can't get it to work.
I have search the forum and the internet and have tried every guide I can find but none seem to apply to Fibre to property as they suggest using the Fritzbox insyead of the Openreach modem but the Openreach modem is getting a fibe input and the fritzbox can't handle that.
I have tried setting it up as using the openreach modem using every setting I can find anyone recommending without any joy.
Several posts suggest replacing the cable which comes with the home hub 4 (the one with red connections) with the one that comes with the fritzbox but the connections are not of the same type.
Has anyone managed this and would they be kind enough to share the settings and which cabling they used ?
Tony
1 REPLY 1
Expert
Message 2 of 2
Re: Anyone got a Fritzbox 7390 working with Inifinity 2 Fibre to property ?
