meridius
Message 1 of 8
Anyone using netgear as a hub help?
Hi all
Thanks for any help given. I am getting infinity in a few weeks and wanted to know what netgears hardware you can use for the hub.
Also can you use te netgear as a hub from day one or is it best to use bts hardware for the first 10 days
Next question can u see what sync speeds you have using the netgear as a hub
The last question would it all work the same way as the netgear I have now paper from the modem part like wifi an security and
Network settings
Thanks for any help
[URL=http://www.speedtest.net][IMG]http://www.speedtest.net/result/2759601729.png[/IMG][/URL]
7 REPLIES 7
Message 2 of 8
Re: Anyone using netgear as a hub help?
Hi meridus
I think you are confusing what equipment you need.
BT Retail provide a Home Hub3 which is a router that handles both wireless and  wired connections. A hub is a different piece of equipment which gives more ethernet connections and are really outdated as ethernet switches are faster and only a few pounds more.
THe HH3 has 4 ethernet ports, only one of which is a fast gigabit port and the wireless connections give some people problems. You can safely replace the Home Hub with a cable router of which there are loads including the Netgear N900, choose one with the services you need the N900 has dual band wireless which is nice if you need it but not cheap. The router cannot increase the speed of the connection but look for gigabit ports as 100mbps ports are nearing their limit with Infinity.
BT Openreach provide a modem which handles the connection to the cabinet and sets the overall speed. Netgear do not offer a combined modem router for VDSL connections like Infinity and you are best not changing the modem unless you know what you are doing.
meridius
Message 3 of 8
Thanks for the info
Abitt of a let down about only having one gigabit port. I have 2 network cables comming into my room. So this means I would have to buy a gigabit switch to plug into the gigabit plug of the bt hub3 ang my network into the gigabit switch.
Does the modem plug into the 100mb socket or the gigabit ?
Abit poor on bts part why not just put 4 gigabit ports on there.
Cheers
Distinguished Expert
Message 4 of 8
A 5-port gigabit switch is under £20
meridius
Message 5 of 8
Cheers.
So u must plug the switch in the gigabit socket and the modem in the 100mb socket.
I might just get a new router at least I know how netgears work and I like there interface.
I hope manufactures start bringing there own Vdsl combos out as the uk is getting more and more connections like that.
Guru
Message 6 of 8
Hi meridus, here's a good thread showing good and popular replacements for the HH3, http://community.bt.com/t5/BT-Infinity/List-of-Routers-to-replace-Home-Hub-3/m-p/298203/highlight/tr...
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
Message 7 of 8
@meridius wrote:
Cheers.
Meridus
The modem plugs into the red WAN socket which is also Gigabit capable. There are several VDSL routers around like the Draytek Vigor 2850n BUT you are supposed to use the VDSL modem supplied by Openreach and until that changes there is no real market.
meridius
Message 8 of 8
Cheers for the help
