bill78
Newbie
Message 1 of 2
Anyone using the Cisco RV220W instead of the HH3?
Hi there,
Has anyone had any experience good or bad of the Cisco RV220W router in place of the Home Hub?
It supports PPPoe so on paper should work.
I'm after a router that has wireless, can do VPN (IPSEC & PPTP) and dynamic DNS.
Thanks in advance,
Bill
1 REPLY 1
Sage
Sage
Message 2 of 2
Re: Anyone using the Cisco RV220W instead of the HH3?
Haven't used that router but as you say it supports PPPoE then it will work without any problems.
I've tested several different makes of router and not had a problem.
