mikeydarlo
Message 1 of 2
App improvement suggestions
For me the app seems pretty good but I have some ideas for improvements...
Stream bitrate quality options. As YouTube does maybe an option to select higher or lower quality streams to suit varying broadband speeds
In the fixture lists highlight which matches are live on btsport
Have an option to set alerts for the sports you're interested in so you don't miss any. Ie get a push notification to your ipad or android whenever a premiership match is about to kickoff live on btsport
1 REPLY 1
Moderator-Retired
Message 2 of 2
Re: App improvement suggestions
The stream automatically adjusts depending on the speed of the broadband connection being used.
You can send this feedback directly to the app team by entering the app, clicking on Menu, the Settings button, then Feedback.
Dean
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
