Message 1 of 3
Apple TV 2021 - Dolby Vision
Hi guys
Got United vs Leeds on, playing in Dolby Vision and Dolby Atmos.
1gbps internet, still seems like the FPS is not quite right, doesn’t feel like it’s playing at 60 fps.
Tried it on the Xbox series X and the picture is smoother, but the reason I replaced that as my device is there an odd stutter most of the time when a ball is kicked which is annoying.
Have any others found this with Apple TV, or any suggested settings? Work being done?
2 REPLIES 2
Message 2 of 3
Re: Apple TV 2021 - Dolby Vision
The video is 50fps - set your display output to this and you should find it is much smoother.
Message 3 of 3
Miles better, thank you mate 👌🏼
