Message 1 of 27
Apple devices and BT yahoo mail
I have an iPhone and and iPad which I have set up to receive mail from my Btinternet.com account.  I can receive and read them OK but cannot REPLY or FORWARD those messages.
At the moment I have to do a tedious cut and paste into my iCloud account to reply.
Is there a solution to this as I have heard that some mail providers do not allow message handling in this way?
Is Yahoo one of them?
M
26 REPLIES 26
Message 2 of 27
Re: Apple devices and BT yahoo mail
I just replied to another thread about a Ipad, asking what type of account is setup.
My answers may help.
http://community.bt.com/t5/Other-BB-Queries/Spam-messages-and-the-ipad/m-p/740174#M40747
Message 3 of 27
Hi Keith,
Tryed that reconfiguration which torpedoed the account on my outlook. Have reverted to POP there as the server kept refusing my password.
Will continue to try to manually configure the A/C on the iPhone.
M
Message 4 of 27
I am not sure how to configure Outlook for IMAP as I use Thunderbird, which I believe also has a MAC version.
Using Thunderbird e-mail client
Message 5 of 27
Hi
The issue is with Yahoo not Outlook which I use for other IMAP accounts.  The mail server refuses the password login, but accepts it for the POP configuration.
M
Message 6 of 27
@MarkCheshire wrote:
Hi
M
If you look at the settings that I use for Thunderbird, it may give you a clue. Sometimes it can simply be a port or authentication issue.
AndyN is our forum  expert on e-mail, so he may appear later and offer more advice.
Recognised Expert
Message 7 of 27
Hi
M
Sounds like your SMTP configuration isn't right.
Which server, port and SSL configuration are you using ?
Message 8 of 27
Hi Ian
I am using mail.btinternet.com on port 25 with no encryption.  No SSL required.
Any help
M
PS after a long struggle I have got my Outlook running again - password AND security details corrupted at their end!!
Recognised Expert
Message 9 of 27
So you're sorted now ?
Message 10 of 27
NO Just my PC!  The apple devices are still not sending  replys or forwards.
M
