Newbie
Message 1 of 8
Apple devices drop wireless connection
Hello,
I've had Infinity for a few weeks now and every time I use any Apple device, such as an iPod Touch, iPhone or iPad, after a few minutes of loading web pages, updating an app or watching a video it'll disconnect and I'll have to reconnect it again but I don't have to put the password in. it only happens to my Apple devices, wireless works on the PC, laptop, consoles and my Android phone. all the devices are on the latest iOS and the hub I have is the 3.0 one.
any help will be grateful. thanks
7 REPLIES 7
Distinguished Guru
Message 2 of 8
Re: Apple devices drop wireless connection
Try giving them a static IP address
If not, I'll try again 🙂
Newbie
Message 3 of 8
how will I go about doing that
Message 4 of 8
Disable the smart wireless technology in the homehub and make sure you're connected to the correct wireless. I couldn't get an iPad to hold a connection for more than 10 seconds. Seems like the iPad gets confused by the actual wireless access point you're trying to connect to and the open access point that the home hub also dishes out. Disable the smart technology, connect to the password protected access point and it should be fine.
Newbie
Message 5 of 8
thanks, ill give that a try shortly
Newbie
Message 6 of 8
Just to confirm none of these methods worked what so ever, but thanks for the replies
Distinguished Guru
Message 7 of 8
Best thing to do maybe is buy a better router. Unless you have BT Vision.
Newbie
Message 8 of 8
I am debating on whether to get the new hub 4.0 which has dual band wireless
