Willstar
Message 1 of 6
Application Sharing / port forwarding broken?
Hi,
I've got a QNAP 419 server hooked up to my HomeHub1 and I've had HTTPS / HTTP / FTP all running nicely.  For some reason all the ports now seem to be blocked.
Using http://www.canyouseeme.org/ just times out on every port.
I've even tried turning the firewall off and setting the DMZ to the QNAP server - no change...
Anyone got any ideas?!
5 REPLIES 5
Willstar
Message 2 of 6
Re: Application Sharing / port forwarding broken?
OK, so the HH3 updated to .57 last night.  Something has changed too.  with the firewall off and the DMZ set to the QNAP at least I now get "non-blocking" result from canyouseeme on ports 21 and 80.
However, I still cant see the web or secure web server when tapping in the URL via DYNDNS or even my current IP address...
Willstar
Message 3 of 6
with the firewall back on and the DMZ removed ports 21 and 80 are still unblocked... not sure what's going on. 😞
Willstar
Message 4 of 6
I should note that I tried the HH1 again last night and I still couldn't access my server externally... so perhaps not an issue with the home hubs...
Willstar
Message 5 of 6
Not sure what's changed (i've not changed anything!) but the problem seems to have fixed itself!
Thanks to the IT Gods! Smiley Tongue
Willstar
Message 6 of 6
I should add that the "problem" isn't really resolved, something changed that now prevents me connecting to my local server via DYNDNS / IP address from the local network.  No matter!  Access is fine on a "foreign" network (tested it from work)
