TrickyDicky
Message 1 of 85
Are HD Films & 5.1 surrond sound working yet!!!
Has BT sorted the above out yet ............. ???????
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings Star on the left-hand side of the post.
84 REPLIES 84
ab79
Message 2 of 85
Re: Are HD Films & 5.1 surrond sound working yet!!!
If you mean surround outputted through optical then yes. But only after starting the film then changing the optical from surround to stereo and then back again. I'm sure this will get fixed in an update at some point. If you mean surround via HDMI then I don't know, my av amp is not that good/modern!
GraemeF
Message 3 of 85
Re Being able to watch HD Films in Surround via HDMI......... NO! Not unles you do the workaround of switching off surround before watching then switching back surround back on. But i would risk it for a bx office. Once Bitten.....
PJ_Maybe
Message 4 of 85
Would be nice if a mod did some investigation into this to let the customers know whether this fault has been acknowledged and when it may be properly fixed.
It's hard to recommend the service if it does not work properly.
thisisgil
Message 5 of 85
Working over HDMI for some (not all) HD films after you switch to stereo and then back to surround after the film has started playing......
PJ_Maybe
Message 6 of 85
Yes I know that there is a workaround. But this is not a beta.
It is broken, and I think it would be good customer relations to acknowledge it and let your customers know it is going to be fixed, rather than make it appear that you don't care. Not all customers search through forums like this.
PJ_Maybe
Message 7 of 85
Bump for response
TrickyDicky
Message 8 of 85
Another Bump for Official Response (Please!!!)
PJ_Maybe
Message 9 of 85
And again. Bump.
Has this been acknowledged, and if so when will it be fixed?
DavidM
Moderator
Moderator
Message 10 of 85
Hi guys,
Thanks for posting. I'll chase this up and see what I can find out. As soon as I get anything I'll post it up.
Cheers
David
