kevmufc83
Message 1 of 6
Are the stats normal
I could someone tell me if these stats are ok please
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days,
00:05:05
Downstream:5.344 Mbps
Upstream:448
Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex
A
Latency type:Fast
Noise margin
(Down/Up):
6.2 dB / 24.0
dB
Line attenuation
(Down/Up):
49.8 dB / 31.5
dB
Output power
(Down/Up):
19.4 dBm / 12.5
dBm
FEC Events
(Down/Up):
0 / 0
CRC Events
(Down/Up):
56 / 0
Loss of Framing
(Local/Remote):
0 / 0
Loss of Signal
(Local/Remote):
0 / 0
Loss of Power
(Local/Remote):
0 / 0
HEC Events
(Down/Up):
20 / 0
Error Seconds
(Local/Remote):
8 / 0
5 REPLIES 5
raymie67
Expert
Message 2 of 6
Re: Are the stats normal
best to do a BT speed test as well and post that, you want to find what your IP profile is and that is the only way to telll
If my post was helpful then please click on the Ratings star on the left-hand side If the the reply answers your question fully then please select ’Mark as Accepted Solution’
kevmufc83
Message 3 of 6
here is the the result from bt speed test
Test1 comprises of two tests
1. Best Effort Test: -provides background information.
 Download Speed
 3556 Kbps
0 Kbps4000 Kbps
Max Achievable Speed
Download speedachieved
during the test was - 3556 Kbps
For your connection, the acceptable
range of speedsis 1200-4000
Kbps
Additional Information:
Your DSL Connection Rate
:5472 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for
your line is - 4000 Kbps
The throughput of Best Efforts (BE) classes
achieved during the test is - 3.42:16.09:80.51 (SBE:NBE:PBE)
These
figures represent the ratio while sententiously passing Sub BE, Normal BE and
Priority BE marked traffic.
The results of this test will vary depending
on the way your ISP has decided to use these traffic classes.
2. Upstream Test: -provides background information.
 Upload Speed
 318 Kbps
0 Kbps448 Kbps
>Upload speed
achieved during the test was - 318 Kbps
Additional
Information:
Upstream Rate IP profile on your line is - 448
Kbps
We were unable to identify any
performance problem with your service at this time.
It is possible that any
problem you are currently, or had previously experienced may have been caused by
traffic congestion on the Internet or by the server you were accessing
responding slowly.
If you continue to encounter a problem with a specific
server, please contact the administrator of that server in the first
instance.
Please visit FAQ
section if you are unable To understand the test results.
Message 4 of 6
stats look good but profile at 4000 should be 4500 for your current speed  stable connection and should rise to normal
kevmufc83
Message 5 of 6
What are the CRC events, HEC events and the Error Seconds as these seem to be higher the longer im connected
FEC Events
(Down/Up):
0 / 0
CRC Events
(Down/Up):
144 / 8
Loss of Framing
(Local/Remote):
0 / 0
Loss of Signal
(Local/Remote):
0 / 0
Loss of Power
(Local/Remote):
0 / 0
HEC Events
(Down/Up):
115 / 0
Error Seconds
(Local/Remote):
359 / 29
Message 6 of 6
easier to post this so you can read at your leisure http://www.kitz.co.uk/adsl/linestats_errors.htm
