Dark_Light
Message 1 of 6
Are these error rates normal
I recently got upgraded to 21cn, and for the past 2 weeks I have had drop outs. I found the source of this and it seems to be ok. However as a result of the drop outs my line speed is capped, so I have a few questions.
1. How long does it take for that cap to be removed.
2. What are acceptable error rates.
3. Does the max speed take noise margin into consideration?
4. If the cap is removed and my noise margin does decrease, what will I sync at?
Line stats.
DSL Line (Wire Pair):Line 1 (inner pair)
Protocol:G.DMT2+ Annex A
Downstream Rate:8126 kbps
Upstream Rate:444 kbps
Channel:Interleaved
DSL Down Up
Current Rate: 8126 kbs 444 kbs
Max Rate: 13505 kbs 876 kbs
Current Connection:
 Current Noise Margin: 15.1 dB 28.1 dB
 Current Attenuation: 33.9 dB 12.6 dB
 Current Output Power: 20.7 dBm 12.6 dBm
General Information
Downstream Rate Cap:8128 kbps
Downstream Atten. at 300kHz:26.7 dB
Uncancelled Echo:-22.4 dBOk
VCXO Frequency Offset:4.7 ppmOk
Final Rx Gain:15.1 dBOk
Impulse Noise Comp. Tones:0Ok
Excessive Impulse Noise:0Ok
Impulse noise protection:1.68
Delay of latency path:7.99 ms
Error stats for about 14 hours.
ATM Since Reset Current 24-Hour Interval Current 15-Minute Interval Time Since
Last Event
Cell Header Errors: 18 18 0 0:07:40
Loss of Cell Delineation: 4 4 0 0:07:40
DSL
Link Retrains: 0 0 0 0:00:00
DSL Training Errors: 0 0 0 0:00:00
Training Timeouts: 0 0 0 0:00:00
Loss of Framing Failures: 0 0 0 0:00:00
Loss of Signal Failures: 0 0 0 0:00:00
Loss of Power Failures: 0 0 0 0:00:00
Loss of Margin Failures: 0 0 0 0:00:00
Cumulative Seconds w/Errors: 13 13 0 0:07:40
Cumulative Sec. w/Severe Errors: 0 0 0 0:00:00
Corrected Blocks: 2954 2954 407 0:00:21
Uncorrectable Blocks: 16 16 0 0:07:40
DSL Unavailable Seconds: 0 0 0 0:00:00
5 REPLIES 5
davesmeg
Message 2 of 6
Re: Are these error rates normal
I would love to have those stats.
My down attenuation is over 50db.
Dark_Light
Message 3 of 6
What are you error rates, CRCs etc.
hamish72
Recognised Expert
Message 4 of 6
http://www.kitz.co.uk/adsl/error_correction.htm    is a good site for info
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
Dark_Light
Message 5 of 6
Since I wrote this thread I have got some more drop outs, is the occasional drop out normal?
Statistics
Collected for 16:14:28
 Since ResetCurrent 24-Hour IntervalCurrent 15-Minute IntervalTime Since Last Event
ATM Cell Header Errors:323240:02:26
ATM Loss of Cell Delineation:5500:42:46
DSL Link Retrains:4400:23:30
DSL Training Errors:5500:23:09
DSL Training Timeouts:0000:00:00
DSL Loss of Framing Failures:0000:00:00
DSL Loss of Signal Failures:0000:00:00
DSL Loss of Power Failures:0000:00:00
DSL Loss of Margin Failures:0000:00:00
DSL Cumulative Errored Seconds:252530:02:26
DSL Severely Errored Seconds:0000:00:00
DSL Corrected Blocks:34743474600:00:09
DSL Uncorrected Blocks:303040:02:26
ISP Connection Establishment:44420:50:10
davesmeg
Message 6 of 6
Must be having a good day.
Noise margin (Down/Up)15.2 dB / 25.0 dB
Line attenuation (Down/Up)44.0 dB / 26.5 dB
Output power (Down/Up)19.8 dBm / 12.2 dBm
