oakserver
Message 11 of 14
Re: Asus DSL-AC68U Update
Hi,
Yes I was successfully able to increase sync speed by tweaking the SNR stability on the new Asus firmware. I only risked going down as far as 4db but the connection seems stable with no increase in CRC errors. Put it back to 5db though as I prefer complete reliability over speed gains.
jamjar62
Expert
Message 12 of 14
Yes i am on 4db  and it seems to run stable with 3mb higher speed than 5db  🙂 the ping is high but i don,t play games so not an isssue for me 🙂  I will run it for the next week and see if anything happens ,i think it should run fine  the SNR  is 3.8 or 3.9 db  so it seems stable for now ,but as i said if i get problems  i,ll be back to  5db 🙂
JamJar62
Fraz56
Message 13 of 14
I have updated the DSL AC68U to the latest firmware and now BT TV will not work. It worked perfectly previously. Any ideas?
TimCurtis
Guru
Message 14 of 14
Try powering off the Youview box for 30secs or so.
