jamjar62
Expert
Message 1 of 3
Asus DSL-AC68U modem/ router setting up help
Hi All   I am wanting some info/help regarding the setting up of the Asus DSL-AC68U Router/modem ,apart from the username & password  details are there any advance settings i will need to change or add ?   🙂
JamJar62
2 REPLIES 2
brookheather
Expert
Message 2 of 3
Re: Asus DSL-AC68U modem/ router setting up help
Just ensure G.INP is enabled - ideally you will be on FastPath for both downstream and upstream.  Leave it for a few days and see how stable it is - you can adjust the target SNR for more stability or more performance - if your line drops you can increase the SNR above 6db - if everything is fine you can reduce the SNR to 5db for a bit more performance unless you are already receiving maximum sync rates.
licquorice
Message 3 of 3
If it doesn't automatically set it, VLAN id is 101.
