Riggie88
Message 1 of 4
Asus N16U
Good evening,
I've purchased the router in the title and I'm having a little trouble connecting to the internet with it.
I'm still using my original modem because I'm aware that I would need a VDSL one for a one box solution.
On the 'quick internet setup' program, it won't go past the 'DSL Line Configuration' page. I select which annex I want, press next, it starts to detect my connection type and it just goes back to the DSL line configuration page.
Don't suppose anyone would be kind enough to lend me a hand setting this up?
Craig
3 REPLIES 3
ray_dorset
Distinguished Guru
Message 2 of 4
Re: Asus N16U
The modem LAN1 should connect to the router WAN using an ethernet cable. Scenario 2 below
If not, I'll try again 🙂
Riggie88
Message 3 of 4
Re: Asus N16U
I've connected the devices using scenario 2 🙂
I've been into WAN settings, 'WAN transfer mode' is set to 'ADSL WAN (ATM)'.
In the PPP settings, I've put bthomehub@btbroadband.com as the username and the password left blank. But the DSL connection screen still does the same thing
Craig
licquorice
Message 4 of 4
Re: Asus N16U
Have you set the wan port to pppoe? Try putting a space or bt as password.
