is there anything listed for your area https://www.bt.com/consumerFaultTracking/public/faults/tracking.do?pageId=31
You just need to be insistent with CS that you need an engineer visit.
What did you check at at master socket test port ?, ideally you should check for dial tone with a known working phone , preferably a corded phone, if there is no dialtone at the test port, report NDT ( no dialtone ) to your landline provider (phone service fault not a broadband fault) ....if they advise of the potential for charges, it's because the line test may indicate the problem is at or close to your home , but if it's NDT at the test port ( this is the demarcation point between your responsibility and Openreach's responsibility ) then you can say OK to thus warning , as there shouldn't be any charge to you.
if you don't normally have a phone plugged in, I would suggest buying a cheap (£5 ish) landline phone , or borrow one from a neighbour or friend) to try this, if you do have dialtone, dial 17070 and check the number read back to you is the correct phone number, if it isn't the correc number, again report the fault as a phone problem...if dialtone present and the correct number , all you can do is speak to your ISP again
If you have a dialtone , with the correct number, and your hub isn't connected (Orange light) , that is the sort of issue that the ISP should accept and deal with without any fuss, it's unclear why they wouldn't just raise a fault report, if you confirm you are plugged into the test port and have dialtone.
The chances are it's either the hub is faulty ( and if the hub is less than a year old it's under warranty ) or your Infinity connection has been disturbed in the street cabinet , possibly by an engineer working on an adjacent line.
Why would you keep an eye on the street cabinets if they haven't accepted and reported your problem to Openreach ?, even if , coincidentally , an OR person turned up, they wouldn't have your line/circuit details so couldn't deal with your issue, have BT accepted your problem and issued a fault report to OR ?
@LUKEW1985 I'm sorry about the fault with your broadband. Please use the 'click here to contact the mods' link in my forum profile to send in your details and we'll be happy to find out what's happening. You can find the link by clicking on my username.
Neil
Which exchange?
