Message 21 of 34
Re: At my wits end re Saga of erratic Broadband connection speed and poor BT service support
for the most reliable speedtest results they should be done with a wired connection as wireless is subject to to many errors
Message 22 of 34
there is no relation to speed and the installation of infinity as the infinity installs are done at the street cabinets (new ones)and not at the exchange as is the normal adsl service a lift and shift is only done if there has been major problems with a connection and every other check and test has failed
colonel25
Message 23 of 34
Well I'm just puzzled how the connection speed can be all over the place since yesterday.  If you see just this morning alone, it makes no sense to me how the speed can be this erratic if there is no problem with the line.
UploadDownload
12th May 2012 13:53:43905 Kbps14948 Kbps
12th May 2012 11:10:22917 Kbps6919 Kbps
12th May 2012 10:27:11914 Kbps5568 Kbps
12th May 2012 09:23:11916 Kbps11306 Kbps
12th May 2012 09:14:42917 Kbps13390 Kbps
12th May 2012 08:45:37915 Kbps10206 Kbps
12th May 2012 08:34:08915 Kbps11814 Kbps
12th May 2012 08:19:49907 Kbps15995 Kbps
12th May 2012 08:11:29943 Kbps11462 Kbps
12th May 2012 08:01:57951 Kbps6918 Kbps
12th May 2012 07:59:50955 Kbps7264 Kbps
12th May 2012 06:19:13951 Kbps10094 Kbps
12th May 2012 05:26:41955 Kbps3705 Kbps
Message 24 of 34
your download speed will vary constantly depending on general internet usage and time of day which speedtest did you use for the speedtest results you posted as that can also differ from speedtester to speedtester
colonel25
Message 25 of 34
Using BB Max for all tests. Never had such a wide variation of speed in the preceding two years. I accept that speed will very at peak times during the day
Message 26 of 34
try some tests using the BT beta test speedtest in comparison
colonel25
Message 27 of 34
ALready done so John, see earlier post and comparison between BT Speedtest and BB Max
Message 28 of 34
yes i saw the one with the one BT beta test i was meaning a similar series of tests to those you had done with the bbmax tester to see if it showed the same sort of trend
colonel25
Message 29 of 34
Hi John,
Yes I have done a number of tests with the BT Speed test and the results reflect the BBMax results.  I always use BBMax because it is pretty consistent and I have been using this to monitor speeds for about 5 years now.  I can also tell you that I have run the speedtest both over my wireless network and also direct ethernet connection to the BT Hub.  Results are slightly lower over wireless but only by about 256 to 512 Kbps, so I conclude that as my speed drops by as much as 13 Mb it is not a wireless issue but more likely an exchange issue.  I have been speaking to BT BB today and they say they have tested the connection at the exchange ? And found a fault which they are dealing with BT wholesale about.  Call me cynical but I don't know if this will resolve the issue.  Let's hope so.
Regards
Paul
Message 30 of 34
be interesting to see if there is a fault as that is becoming a script answer from the helpline
you can check the exchange for problems here  http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
