Hi, can anyone explain why I cant sent pics with my txt. BT sim card in a Blackberry. Thanks
text with pics is MMS and that is not included as part of your package. You would need to top up with money in addition to your monthly amount and it would run down as you sent MMS. Similar to giffgaff
Is that right, that out of plan charges have to be paid in advance? If so it's another reason not to switch to BT Mobile.
unless they just add it to your bill at the end - don't use BT mobile so just going on giffgaff
It may be that @MellingBob has not set up the MMS information in network setup hence it does not work
Any additional charges like text outside your calling plan are billed separately on you mobile bill.
Stew
Good! That's how it should be, spending as much as you want subject to any pre-arranged cap.
