Navrig
Message 1 of 7
Attempts to fraudulently access my PC
I took a call from an asian gentleman today who claimed to be from "Windows" and that he wanted to help me clean my computer because it was downloading malicious software etc.
I told him to go away (in the politest terms of course).
1471 revealed the caller's number to be:
02031291891
I Googled that number and got a long list sites which record that this is a fradulent attempt.
In this day and age why are BT not blocking these numbers even if they are hijacking them from India?  It's clearly a commin issue.
6 REPLIES 6
john46
Message 2 of 7
Re: Attempts to fraudulently access my PC
BT cannot block the number as it most likely not a BT line and is a VOIP line and could be changed regularly this windows scam has been going on for years now
Navrig
Message 3 of 7
I thought that may be the case......Smiley Mad
ivinsp
Message 4 of 7
See Choose to refuse as this will enable you to block up to 10 seperate numbers yourself
http://www.productsandservices.bt.com/consumerProducts/displayTopic.do?topicId=28921
Choose to Refuse
Stop unwanted or nuisance calls.
  • Prevents unwanted or nuisance calls getting through to you.
  • If you frequently receive unwanted or nuisance calls from a particular number, you can block that number – this block can be removed whenever you like.
whitefalcon
Message 5 of 7
That's terrible. How do the scammers do that? How do the access your computer?
whitefalcon
Message 6 of 7
I found several threads at Callercenter.com about callers asking for access to people's computer. I'm surprised to know that this scam's been going on for a while already.
Nethelp22
Message 7 of 7
In the long run it is more economical to buy a CPR Call Blocker
You program them to disable VOIP, witheld numbers
and can zap/block as you go along
you need called ID enabled for this to work
better still , phones are not too expensive these days:
 buy a BT nuisance call blocker phone like this one
http://www.shop.bt.com/products/bt6500-nuisance-call-blocker---single-8H3D.html
