fawkea
Message 1 of 2
B62 connection issues - any tips?
Hi,
Seem to be having a few issues in the B62 area. All devices are able to successfully connect to the home hub, but the home hub isn't connecting to the Internet!
I've done a hard and soft reset on the hub, but unfortunately I'm unable to access the home hub manager. Anyone got any ideas what else I can try on my end?
(if it's any help, my personal PC which uses an external wireless antenna is suffering with a DNS error as well)
Look forward to any responses!
1 REPLY 1
NeilO
Moderator
Moderator
Message 2 of 2
Re: B62 connection issues - any tips?
@fawkea I'm sorry about the delay getting back to you, did you manage to get this sorted?
