NetBod
Message 1 of 14
BB Speed dropped to 288Kbps from 15 to 18Mbps
Hi
Over the last week I have noticed that my BB connection had been running really slow, some on line apps don't even work any more. So over the weekend I have done some investigation and found that my BB download speed has dropped from around 15 to 18Mbps to 288Kbps, upload speed has dropped from around 1.5Mbps to 488Kbps. All seem to start after the bad weather last week and a power outage in the village.
Done all sorts of tests etc at home, cables replaced, router replaced etc etc, nothing made any difference, still get the same speeds. So yesterday I tried to run the BT speed tester, but the speed is so bad it would not run, some couldn't see what the IP profile is on the line, so run the speed tester today from work, I know the reading for the line speed are wrong, but it lets me see what the IP Profile is configured on my line, pic below of the test results for my line number.
Now I can see that the IP Profile for my line is wrong (or default back to some default or something) and it explains why I am only getting 288Kbps on the ADSL. So posting this new post for info and also contacting BT via help to see if it can be corrected, not sure what the IP profile for the line should be thou as never had any issue with it since it was was installed many years ago now........ Any body any ideas what it should be for an Option 3 plan.....??
Cheers
Tim
13 REPLIES 13
Message 2 of 14
Re: BB Speed dropped to 288Kbps from 15 to 18Mbps
the stats are confusing - are you on adsl broadband option 3 up to 20mb or on infinity?
NetBod
Message 3 of 14
BT Total Broadband Option 3, remember the Downloand and upload speeds achieved in the pic and during the test are via a work's internet connection as I can't run the tester at home due to the line being so slow. All I was looking for was the IP Profile for the line when I ran it at work this morning to check the IP Profile was correct, which its not. Would love to get infinity, unfortunatley thats years away for the village I live in Smiley Sad
Message 4 of 14
I know the infinity feelingSmiley Sad
can you post the adsl stats from your router and btspeedtester results if you can run it at home
are there any problems still at yur exchange  http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
NetBod
Message 5 of 14
Ah, the one thing I forgot to bring with me to work the stats from my router, I have before and after stats so will post those tonight or tomorrow depending on the connection when I get home.
Will try the btspeedtester again tonight and post results if I can get it to work, not looking likely thou as it keeps erroring out, I can post the nice error page saying error occured....Smiley Happy
Interestingly the Up to 24Mbps Speed Test (Beta) test does work, and shows the low speed, I'll post those as well for ref.
No issues reported at the exchange that I can find anywhere, its the Highley Exchange for ref.
Cheers
Tim
Message 6 of 14
that's ok  just post stats when you can
NetBod
Message 7 of 14
Hi
Router Stats, before and after the issue started
Router Stats before the issue started.
Alcatel 20190 chipset information
                 ATU-R (DS)                      ATU-C (US)
Modem Status:    Showtime (DMTDSL_SHOWTIME)
DSL Mode:        ITU G.992.5 (ADSL2+) Annex A
ITU STD NUM:     0x03                            0x2
Chip Vendor ID:  'STMI'                          'IFTN'
Chip Vendor Specific:  0x0000                    0x71BE
Chip Vendor Country:   0x0F                      0xB5
Modem Vendor ID: 'CSCO'                          '    '
Modem Vendor Specific: 0x0000                    0x0000
Modem Vendor Country:  0xB5                      0x00
Serial Number Near:    FHK100652V 1801/K9
Serial Number Far:
MoChip ID:       C196 (0)
DFE BOM:         DFE3.0 Annex A (1)
Capacity Used:   99%                             100%
Noise Margin:     1.5 dB                          6.0 dB
Output Power:    20.0 dBm                        12.5 dBm
Attenuation:     14.0 dB                          6.0 dB
FEC ES Errors:    0                               0
ES Errors:        6                               0
SES Errors:       5                               0
LOSES Errors:     1                               2
UES Errors:       0                              105
Defect Status:   None                            None
Last Fail Code:  None
Watchdog Counter: 0x67
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction:     0x00
Interrupts:      4148 (0 spurious)
PHY Access Err:  0
Activations:     1
LED Status:      ON
LED On Time:     100
LED Off Time:    100
Init FW:         init_AMR-4.0.015_no_bist.bin
Operation FW:    AMR-4.0.015.bin
FW Source:       embedded
FW Version:      4.0.15
                  DS Channel1      DS Channel0   US Channel1       US
Channel0
Speed (kbps):             0            16279             0              1208
DS User cells:              0            27582
US User & Idle cells:                                         0           161551
Reed-Solomon EC:       0                0             0                 0
CRC Errors:                 0              192             0                32
Header Errors:             0              138             0                 7
Total BER:                0E-0           2392E-8
Leakage Average BER:      0E-0           2392E-8
Interleave Delay:         0               58             0                12
Bitswap:               enabled            enabled
Router Stats After Issue Started
Serial Number Far:
MoChip ID:       C196 (0)
Capacity Used:    2%                             73%
Noise Margin:    24.0 dB                         10.5 dB
Output Power:    15.5 dBm                        13.0 dBm
Attenuation:     16.0 dB                          8.0 dB
FEC ES Errors:    0                               2
ES Errors:        0                               1
SES Errors:       0                               1
LOSES Errors:     0                               1
UES Errors:       0                               0
Watchdog Counter: 0xF1
Watchdog Resets: 0
Subfunction:     0x00
Interrupts:      79842 (0 spurious)
PHY Access Err:  0
Activations:     13
LED Status:      ON
LED On Time:     100
LED Off Time:    100
FW Source:       embedded
FW Version:      4.0.15
Channel0
Speed (kbps):             0              288             0               444
DS User cells:              0            46492
US User & Idle cells:                                       0         20331313
Reed-Solomon EC:       0                2             0                12
CRC Errors:                 0                0             0                 0
Header Errors:            0                0             0                 0
Total BER:                0E-0           0E-0
Leakage Average BER:      0E-0           0E-0
NetBod
Message 8 of 14
Also here are the BT speedtester beta test results for the ADSL line
BT Speedtester just will not run on the ADSL link just errors out all the time..
Message 9 of 14
this looks like a banded profile due to drops in connection or you trying to resolve the problem by making may changes causing many resets of your connection
the exchange see all the drops/resets as a line problem and then normally increases the noise margin and drops your conenction speed to stabilise your connectiom.  If the drops continue then you end up in a banded profile - nothing to do with ip profile - and if your line remains stable 24/7 for 3+ days then the banding should release and your connection should improve.  If you get 3+ days and connection speed still at 288 then you need to contact the mods to get banding removed.
contact mods
can take up to 3 working days for mods to contact you
but only after you can show 3+ days stable connection
NetBod
Message 10 of 14
Hum, interesting, where are you seeing all these drops and resets in the above DSL stats......and shown above are due to the line dropping or exchange issues, I have not amened the configuration of the router for 6 months plus, and its on 24/7 unless i'm away. Yes the routers has been moved, cables change etc over this last weekend to eliminate any internal issues before posting this post and getting a call rasied after it started to only showed 288.....
I find it strange that the line is banded as up the point of the bad weather and power cut I was getting 16 odd meg and since power came back on 1.5 hour after it cut off I only get 288Kbps......
Will wait and see what happens..........
