Alvie1974
Message 1 of 39
BB connection issues
Guys,
An engineer attended site on 2 January, i had complained the line was noisy and my BB speeds fluctuated. he reported back, no problems with the line. however, my line went to 4.5Mbs when he left. since then i have watched my BB go up and down from 0.15 Mbs to 4.5 mbs when i reset the HH3, it climbs, the BB goes altogther when i receieve a telephone call. i can reset and all is well again. My BT HH3 is connected directly into my NTE5....  can anybody help? i have attached my ADSL stats from this morning.
ADSL Settings VPI/VCI: 0/38 Type:
PPPoA Modulation: G.992.1 Annex A Latency type: Interleaved Noise margin (Down/Up): 10.2 dB / 16.0 dB Line attenuation (Down/Up): 49.5 dB / 31.0 dB Output power (Down/Up): 19.6 dBm / 12.6 dBm FEC Events (Down/Up): 283319 / 120 CRC Events (Down/Up): 285 / 62 Loss of Framing (Local/Remote): 0 / 0 Loss of Signal (Local/Remote): 0 / 0 Loss of Power (Local/Remote): 0 / 0 HEC Events (Down/Up): 1749 / 34 Error Seconds (Local/Remote): 500 / 74
38 REPLIES 38
imjolly
Message 2 of 39
Re: BB connection issues
can you connect to test socket and repost stats please
also try quiet line test  dial 17070 option 2  should be quiet and best with corded phone   if cordless then dull hum normal
john46
Message 3 of 39
when you repost your stats can you please ensure you add the connection time as well
Alvie1974
Message 4 of 39
Guys, thanks for response. I cannot find a filter to complete the test you asked. I have remove the telephone, reset the HH3 and re run the test. I have no extension wiring to complicate matters. I will grab filter today and do further test, without resetting HH3, I will leave telephone disconnected too.
Line state:
Connected
Connection time:
0 days, 01:11:57
Downstream:
4.688 Mbps
Upstream:
448 Kbps
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.1 Annex A
Latency type:
Interleaved
6.0 dB / 16.0 dB
49.4 dB / 31.0 dB
19.9 dBm / 12.6 dBm
70075 / 0
28 / 0
0 / 0
0 / 0
0 / 0
97 / 0
27 / 0
john46
Message 5 of 39
Please avoid manual resets of your connection as you will cause yourself more connection speed issues can you please run the further diagnostics part of the BT speed test this test appears after the first test completes http://speedtest.btwholesale.com/
Alvie1974
Message 6 of 39
Download speed 4.37
upload 0.35
ping 50.75 ms
OK, noted will avoid resetting.
imjolly
Message 7 of 39
you need to re-run btspeedtester and when first test completes then run further diagnostics and post the resultd
Alvie1974
Message 8 of 39
Speed test results up 4.36 down 0.35 ping 78.13 Line state: Connected Connection time: 0 days, 04:09:04 Downstream: 4.688 Mbps Upstream: 448 Kbps VPI/VCI: 0/38 Type: PPPoA Modulation: G.992.1 Annex A Latency type: Interleaved Noise margin (Down/Up): 5.4 dB / 16.0 dB Line attenuation (Down/Up): 49.4 dB / 31.0 dB Output power (Down/Up): 19.9 dBm / 12.6 dBm FEC Events (Down/Up): 283010 / 6 CRC Events (Down/Up): 136 / 0 Loss of Framing (Local/Remote): 0 / 0 Loss of Signal (Local/Remote): 0 / 0 Loss of Power (Local/Remote): 0 / 0 HEC Events (Down/Up): 892 / 1 Error Seconds (Local/Remote): 103 / 0
imjolly
Message 9 of 39
still need diagnostic test as that will show more information including profile - at present you are just running the first test
Alvie1974
Message 10 of 39
1. Best Effort Test: -provides background information. Download Speed 4.36 Mbps 0 Mbps 4 Mbps sorry, see below.... Max Achievable Speed Download speedachieved during the test was - 4.36 Mbps For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps. IP Profile for your line is - 4.23 Mbps 2. Upstream Test: -provides background information. Upload Speed 0.35 Mbps 0 Mbps 0.45 Mbps Max Achievable Speed Upload speed achieved during the test was - 0.35Mbps Additional Information: Upstream Rate IP profile on your line is - 0.45 Mbps
