Will do. Thanks.
Hi David,
It's now just after the 10 day "settling in" period. Although my speed is better than it was, I believe there may still be some room for improvement. Currently my SNR is hovering around the 10.0 mark and has been for about 5 days previously. Could it be that my IP Profile has got "stuck" somehow?
I include current router stats for your perusal.
Interface | Received | Transmitted | ||||||
Bytes | Packets | Errors | Drops | Bytes | Packets | Errors | Drops | |
P4/EWAN | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
P3 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
P2 | 2109990 | 8050 | 0 | 0 | 9549280 | 9199 | 0 | 0 |
P1 | 252750647 | 2051453 | 0 | 0 | 2092297572 | 1819905 | 0 | 0 |
wl0 | 116166159 | 411994 | 0 | 0 | 411893326 | 866314 | 0 | 0 |
wl1 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
Thank you.
Regards
John F
the connection time is missing from the stats you posted.
looks like the DLM is working ok and has now reduced your noise margin down to 10db and speed has increased. as long as your line stays stable the noise margin should continue to reduce and speed increase until noise margin get back to normal 6db
you profile is based on your connection speed not the other way round so to get higher profile your need faster connection speed
Thank you. Herewith system up time:
Regards
John F
