legitimise_sailing
Distinguished Expert
Message 171 of 183
Re: BBC Iplayer not watchable with BT INFINITY - warning!
Works here
To say thanks for a helpful answer, please click the white star
Raymond_M
Message 172 of 183
How Interesting is this?
If I try the link on gg30340 page it denies access but if I try it via my letter above it accesses ok. I merely cut and pasted gg30340's link.
Raymond_M
Message 173 of 183
http://bt.custhelp.com/app/answers/detail/a_id/14094
Having accessed this link it offers the use of BT's PC Health Check Wizard. When I click on the "try the wizard now" link it returns a message that states:
We have detected that you are using an old version of Internet Explorer not currently supported by BT Desktop help. The supported Browsers are :
  • Internet Explorer 6.0 or higher
  • You can upgrade your browser by visiting the Microsoft site
I actually have Internet Explorer 11. Any ideas please how to get past this wall?
gg30340
Message 174 of 183
If you have BTDesktop Help installed I would suggest that you uninstall it. It is not needed on your computer and can cause problems. Have a look through the forum for recent problems with it and IE11. BT Desktop Help is not compatible, in fact it is junk, get rid of it
TrevorC
Message 175 of 183
I'm happy the changing channel option is working for some.  Anyone any thoughts about users like me who are directly connecting via the lan port?
gg30340
Message 176 of 183
Have you checked the BBC Iplayer site incase there are problems there such as this one.
http://iplayerhelp.external.bbc.co.uk/help/announcements/btvision_jan2014
Raymond_M
Message 177 of 183
Thank you for that info.
Ray
DoctorVock
Message 178 of 183
I had BT infinity installed and have watched programmes on bbc iplayer via my iPad and Apple TV box with no problems......until now, when I keep getting the message about having insufficient bandwidth to watch the programme. How can this be when it was ok before? Have BT reduced my service? When the engineer did a speed test on installation, the speed was very good. Cannot remember the figures, but it believe it was around 36 mob download speed. Ample for iplayer. So, BT, what's going on???
sjtp
Guru
Message 179 of 183
You issue may be BT or may be elsewhere.
Are you running wired or wireless?  If wireless, there are lots of other issues that could be slowing you down ... search the forums.
Check your speeds in other ways, such as
  • speedtest.btwholesale.com  (also run Further Diagnostics if the speeds are well below what you were expecting)
  • http://www.thinkbroadband.com/speedtest.html
  • Unfortunately, BBC have removed their very helpful diagnostic test.
TrevorC
Message 180 of 183
Have you read this thread?  The issue seems to be over and beyond the questions you ask.
I think BT have a problem which they are either in denial over or not addressing.
