Keith_Beddoe
Message 101 of 183
Re: BBC Iplayer not watchable with BT INFINITY - warning!
If anyone has the Panasonic Viera TX-L32E30B, I would like to ask a couple of questions please, to try and assist with this problem.
When you select the iPlayer on the Viera Connect Market, and run it, do you select SD or HD quality?
Is your TV connected using wireless, or an Ethernet cable?
DeanM
Moderator-Retired
Message 102 of 183
Those of you who are having this issue and have sent me details, could you please run another full diagnostic test on www.speedtester.bt.com (or www.speedtest.btwholesale.com if the first link doesn't work) and post the results here?
Dean
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
apshep
Message 103 of 183
In answer to a couple of the recent posts from Dean etc:
My TV is a Panasonic TX-L37DT30B - Panasonic say that they are not aware of any issue with the TV
When using iplayer through Viera Connect I generally try to use HD. If that buffers I try lower qualities, but so far if it buffers on one it buffers on all.
Additionally- when iplayer buffers on Viera Connect it also fails through the PS3 so it is a common problem to both.
Both the TV and the PS3 are hard wired to the HH3. The PS3 also fails when on wifi.
On the plus side ...... wait for it......... iplayer on the TV has worked for the last two days without a hitch. Just tried Dragons Den in HD without a problem as well. I'll do the tests for Deanthe later this evening
apshep
Message 104 of 183
9.55pm QIXL and Dr Who (HD) both running without problem. 🙂
TrevorC
Message 105 of 183
Hi Dean,
21:40 Monday 24/09/12
Download  37.57 Mbps
Upload  9.65 Mbps
Ping Latency  19.50 ms
TrevorC
Message 106 of 183
21:45 onwards
Watching 'Mock The Week' on HD.  No buffering Smiley LOL
Psyxologos
Message 107 of 183
I have no problems with BBC iplayer HD either.
Neolithic
Message 108 of 183
Just to throw my experiences in the mix. I was having big problems with iplayer on a LAN cable with a Panasonic TV and also a Roku box via wifi. Both were buffering relentlessly and I couldn't view anything. The solution was to replace the HH3 with a tp-link wr1043nd router and everything now works beautifully.
apshep
Message 109 of 183
5.30pm and iplayer is working on the TV again. So what has changed? Nothing on my setup! Forgot to run the tests last night but will do and post this evening.
apshep
Message 110 of 183
Download speed achieved during the test was - 67.2 Mbps
For your connection, the acceptable range of speeds is 12 Mbps-77.43 Mbps .
Additional Information:
IP Profile for your line is - 77.43 Mbps
Upload speed achieved during the test was - 16.66Mbps
Upstream Rate IP profile on your line is - 20 Mbps
