Splang
Message 11 of 183
Re: BBC Iplayer not watchable with BT INFINITY - warning!
Why has my first post been edited to remove the reference number?
This is my data and if I wish to show it then that is my choice!
john46
Message 12 of 183
This is a public forum it was removed by the forum mods for your security as are email addresses account numbers etc
Paul1360
Expert
Message 13 of 183
OP, iplayer works on both my laptop and PC in SD & HD, So I can only think it has something to do with your setup
iechyd da
infintybbuser
Message 14 of 183
hi...
problem could be with the connection type that ur using
connect by the ethernet cable and see is speed on the iplayer
if no change change the wifi channel of the hub and check
and do the check in non peek internet usage hrs where congestion on the line would be less
Splang
Message 15 of 183
Iplayer stutters and stops on
1) Computer main pc (win 7 64 bit) (wired)
2) Iphone4 (wifi)
3) Humax HD Freesat box (wired)
4) HP Mini notebook running windows 7 starter (wifi)
This is both with a wired and a wifi connection so you can see why I think it is down to Bt infiinity.
The same setup was fine with O2.
Thanks for the suggestions though but still not solution and no contact from BT!!
rationalzombie
Message 16 of 183
How is this topic a warning? Its not a widespread issue.
Title should be...
BBC Iplayer not watchable with BT INFINITY - on any of my digital devices!
If I helped, then consider clicking the star to the left
smob62
Message 17 of 183
hi,  please bear with me as a newbie to this forum.  i have a sony freesat tv model no kdl32w 5810. i have bt infinity and a home hub v3.  these are connected via a lan cable. i have been getting the i player for around 9 months and suddenly it will no longer connect on my tv. The set was taken away from bt and i-player worked fine.  i have a download speed of around 25-26 mb. my tv will connect to xbox live using infinity.  can anyone suggest how to solve this problem.   does anyone have a similar problem, and if so which make of tv is involved.  has this been encountered on panasonic freesat tv models.  i am getting tv signals from the sutton coldfield transmiitter.  can anyone help please.  regards    steve m.
Tags (1)
Davidwalker600
Message 18 of 183
i had this problem as well with iplayers with bbc and itv
ps this only happneds every 30 mins then you have to reload the page
with 40mb download speed and 10mb upload speed with unlimited downloads
on wired network i do not use wireless network that much only over nights
the speed is not going down of my net
uk leyland
HH3
get this sorted pls it is at there side or your side
smob62
Message 19 of 183
hi again, what equipment are you using and where in the country are you please.
sockstango
Message 20 of 183
Hi
I've had the same issue, with the same freesat model, which happened a few days after 'upgrading' to BT Infinity in mid October. Had the TV for over a year with no iplayer issues with BT Broadband. BT infinity speeds are fine and there are no other issues connecting to our PCs. Others appear to have had similar issues noted on Sony forum. Gone round in circles trying to establish with which parties the fault lies - BT Infinity always seems to be ISP...
http://www.sony.co.uk/discussions/thread/138794?start=16&tstart=0
