minusdot
Recognised Expert
Message 1 of 2
BBTalk on Anywhere?
I've seen a number of threads about using BBTalk on the new Anywhere handsets. What's the general consensus? Is it easy enough to set up? Does it work - can you make and receive calls when connected by wifi? Is the call quality good enough?
I used to have the old HTC 620 phone (long dead now) and although it "supported" BBTalk it was unusable.
With the new HH3 not supporting BBTalk, if BT Anywhere can't do it either then it's doomed.
1 REPLY 1
Message 2 of 2
Re: BBTalk on Anywhere?
BBT works on Android o/s phones with the Sipdroid app. Set up no problem via the thread on this forum. Some reports of calls dropping out after 10 mins, but I haven't had that on my HTC Desire. Only used wi fi to date when no network service available.
I used to have the 620 on Anywhere, but now use another SP.
Thumbs up from me for BBT in Android.
AQ.
"Welcome to Royston Vasey - You'll never leave."
