Message 21 of 31
Re: BEEN HAD BY BT ONCE AGAIN ON SPEED!!
just spoken to indai again and they have restet my line for the 3rd time so there saying keep an eye on speedtester and wait 10 days again .. this has been going on since the 5th of march....
think there realy starting to take the mick now........
Message 22 of 31
not confident India will fix this at 3rd attempt - I would contact mods again
Message 23 of 31
well what a differance it is speaking to i take it a english person in the uk by email....
i have just had one of the mods reply by email saying my line is still capped and indea saying it isnt....
but also the mod has said i should notice a difference in speed in the router with in 24hrs and india say no i wont
so who is right ?
but the email says
Hi
Thanks for your email, I am sorry for the delay in getting back to you.
Having gone through the diagnostics today I agree you should be getting a higher speed you still appear to be getting capped at 8meg so I have issued a request to lift this cap to allow your speeds to increase.
Please monitor your connection and should it not increase by the end of today, reply directly to this email.
Stuart
BT Forum Moderator
thanks for the reply stuart but my speeds havent changed and if you could re look into it that would be great
cheers gav
Message 24 of 31
The email from the mods is the one to believe they deal direct with BT wholesale to get things sorted you will also see the speed difference on the router
Message 25 of 31
@john46
should i see a difference in speed as soon as they have said as the email was dated 2 days ago and i have only just seen it as of about 10 mins ago but the speed has not changed up or down
i have replyed to the email saying it hasnt changed
Message 26 of 31
this is the settings of the router as of now
ADSL Line Status
Connection Information
Line state:Connected
Connection time:4 days, 16:56:24
Downstream:7.938 Mbps
Upstream:443.9 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Fast
Noise margin (Down/Up):17.1 dB / 29.2 dB
Line attenuation (Down/Up):26.1 dB / 14.3 dB
Output power (Down/Up):18.2 dBm / 12.1 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):1426 / 41
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):1636 / 11
Error Seconds (Local/Remote):1094 / 9
Message 27 of 31
bump.
Message 28 of 31
depends how fast bt wholesale take on doing the changes worth as you have done sending another mail to the mods they can chase it up
Message 29 of 31
yay looks like were getting some where thanks to the mods here !!!!
ADSL Line Status
Connection time:1 days, 09:27:53
Downstream:15.55 Mbps
Upstream:1.117 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Latency type:Fast
Noise margin (Down/Up):6.3 dB / 6.0 dB
Output power (Down/Up):20.6 dBm / 12.7 dBm
CRC Events (Down/Up):2848 / 117
HEC Events (Down/Up):15654 / 217
Error Seconds (Local/Remote):4844 / 77
FAQ
Results Image not loaded
<script type="text/javascript">// paintProgressAndMessageOnBar(100,"The test has successfully completed" ); // </script> Test1 comprises of two tests
1. Best Effort Test: -provides background information.
Download Speed
6634 Kbps
0 Kbps7150 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 6634 Kbps
 For your connection, the acceptable range of speedsis 2000-7150 Kbps.
 Additional Information:
 Your DSL Connection Rate :15927 Kbps(DOWN-STREAM), 1144 Kbps(UP-STREAM)
 IP Profile for your line is - 7150 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 13.88:21.38:64.74 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
2. Upstream Test: -provides background information.
Upload Speed
894 Kbps
0 Kbps1144 Kbps
>Upload speed achieved during the test was - 894 Kbps
 Upstream Rate IP profile on your line is - 1144 Kbps
Message 30 of 31
spose its just a matter of a few days now for the line to sort its self out for the download speed to inprove ?
