Message 1 of 3
BEWARE: Latest BT Home Hub Update Breaks Wireless for non-Windows/MacOS devices
So, thanks BT. My home office set up is now 50% offline thanks to the latest 'update' (for which read 'downgrade') to the BT Home Hub software.
This line at the bottom of my Hub config: Software version V100R001C01B031SP09_L_B | Time & date 10:49 09/05/2012
All my devices were kicked off and then, only my Windows and MacOS devices reconnected.
Blackberries, iPhones, and Linux devices now refuse to connect.
This is the same issue as was experienced by others some six months ago but, this time, the manual IP address allocation does not seem to solve the issue.
How on earth can BT call themselves a 'telecommunications' company when this sort of thing happens?
I want answers and/or a refund for this continued stupidity.
This will be forwarded to social media. You have been warned.
David.
2 REPLIES 2
Message 2 of 3
Re: BEWARE: Latest BT Home Hub Update Breaks Wireless for non-Windows/MacOS devices
this is a community forum where customers help customers and only BT employees are the forum mods.  your post will not go direct to BT
searching the forum there post both saying problems with the update and others saying it is working ok.  this is not new in respect it was out last year.
you can contact the forum mods and see if the can help
contact mods
can take up to 5 working days for mods to contact you
Distinguished Guru
Message 3 of 3
Hi David and welcome
That firmware has been out for some time and you may be confuisng yourself regarding when this firmware update took place.
You can check when this firmware was installed by following these instructions
log in to the hub GUI
click settings
input password if prompted
adavanced settings
continue to advanced
system
firmware - can you give the 'last updated' date.
-+-No longer a forum member-+-
