Cgm3100
Message 1 of 7
BROADBAND HELP
so I moved into a new property in match and still no internet that is actually useable from bt after 3 engineers. The last engineer found a fault on the phone line and now I have no noise on the line so why has my internet speeds not gone up at all from the unusable speeds off 0.13 Mbps that I am getting? Please help!
6 REPLIES 6
XRaySpeX
Recognised Expert
Message 2 of 7
Re: BROADBAND HELP
Please post your full Router Stats. For a Home Hub see on here: Broadband Top Tips . Full router stats are key to any speed & connection issues.
What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
DavidM
Moderator
Moderator
Message 3 of 7
Re: BROADBAND HELP
Hi @Cgm3100 and welcome.
I'm sorry you're having problems with the connection. If you can post the details as requested by @XRaySpeX I'm sure we'll be able to help.
Cheers
David
Cgm3100
Message 4 of 7
Re: BROADBAND HELP
john46
Message 5 of 7
Re: BROADBAND HELP
your link does not work it is better to post your images directly to the forum
XRaySpeX
Recognised Expert
Message 6 of 7
Re: BROADBAND HELP
That's a file on your PC. We can't see it. Just copy results to a post.
DavidM
Moderator
Moderator
Message 7 of 7
Re: BROADBAND HELP
Hi @Cgm3100,
Thanks for posting. @XRaySpeX and @john46 are correct. Can you copy and paste the results onto your post and we'll take it from there.
Cheers
David
