Message 1 of 13
'BT 2700HGV' vs 'BTHomeHub-50B0'
Hi Forum,
Ive been given a 'BT 2700HGV' and I was wondering if it was any better than my current 'BTHomeHub-50B0'?
Also if the BT 2700HGV is any better will I have any trouble in setting it up?
Any help would be greatly appreciated
Thank you...
12 REPLIES 12
Message 2 of 13
Re: 'BT 2700HGV' vs 'BTHomeHub-50B0'
with your 58 attenuation the 2700HGV may help as it has a good reputation for holding connection on longer lines.
setting up should not be a problem - sign is bthomehub@btinternet.com and no password required
Message 3 of 13
Hey imjolly
Ive seem to be getting kicked a lot with the 'BT 2700HGV' could you help me out please?
I can connect to the hub OK but sometimes Im getting limited acecces....
Ive run a test from within the router menu and Ive atached a sceen shot on the results.
Also shown the place where Ive enterd your sugetted user name but I'm not sure if its in the correct place :S
Any help would be great cheers
<a href="http://www.flickr.com/photos/63624851@N08/5861816592/" title="test-2 by pembo101, on Flickr"><img src="http://farm6.static.flickr.com/5225/5861816592_7d946b8741.jpg" width="500" height="281" alt="test-2"></a>
<a href="http://www.flickr.com/photos/63624851@N08/5861229819/" title="test2 by pembo101, on Flickr"><img src="http://farm6.static.flickr.com/5182/5861229819_4ed22c700a.jpg" width="500" height="281" alt="test2"></a>
Message 4 of 13
sorry my fault  sign in should be bthomehub@btbroadband.com and no password required
Message 5 of 13
Cheers Jolly,
I'll reset the router when I get back from work....
Message 6 of 13
Hi Jolly,
Thank you for all your help.
I had some really great games online last night and didnt get kicked once. My connection seemed consistent with the other players so I'm quite happy ATM....
Thanks again
Si
Message 7 of 13
great enjoySmiley Wink
Message 8 of 13
Distinguished Guru
Message 9 of 13
@Si
If the above is your phone number, it might be a good idea to remove it. This is a public forum and anyone can read it.
-+-No longer a forum member-+-
Message 10 of 13
its was the numeber I'd been given to report my on going problem with BT, stupidly I'd posted it here so I wouldnt loose it. As you can now see someone has taken it down. I've now gotta ring through the regular way again, unless some would be kind and send me the number in a PM?
