Newbie
Message 1 of 3
BT 4500 calls list on one handset not the other
I have a BT 4500 dual handset and my phone contract is with BT including Caller Display.  I used to be able to view the calls list on both handsets but now I can only view it on one of them.  The other handset says "Not available".  Anyone know why?
2 REPLIES 2
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: BT 4500 calls list on one handset not the other
Have you tried turning the offending handset off then restarting it? If that doesn't help it might be on the blink - the helpdesk 0800 145 6789 should be able to advise.
Newbie
Message 3 of 3
Thanks for the suggestion.  It's working OK since I went to Reset in Settings.  Not sure how, because I exited out of the menus without selecting Reset, but it said it was synchronising and that seemed to do the trick. Smiley Happy
